Did you know...?
Did you know...?
Did you know that you can put on a new timing belt without
anybody else figure it out?
- Breaking the plastic cover
- Removing the crank pulley
- Harming the new belt
What trick?? That is how I have always done my belts.
Put engine to TDC
Drop the 2 accessory belts
Take off the cap and dist housing
Remove the 13 10mm bolts that hold the 2 front covers on
Remove balance belt
Adjust tensioner to 3/4 slack
Remove belt from cam gear
Remove tensioner
Slide belt out and around crank pully
Install the belt starting on the upper right side of the pully, leaving it at a 45 degree angle to the timing belt pully. Push the belt up and into the pully going counter clockwise.
The rest is a normal install. I can change them in no more than 2 hours.
Put engine to TDC
Remove balance belt
Remove tensioner
Install the belt starting on the upper right side of the pully, leaving it at a 45 degree angle to the timing belt pully. Push the belt up and into the pully going counter clockwise. .
I've been told you need to lock flywheel/remove puller or break the case. I thought i was 'the man'.
What trick??
What trick??
.........later that evening
You learn some tricks when you have the downfalls I've had.
