AC Delco O2 sensor
Old Nov 3, 2013 | 12:07 PM
odonnell's Avatar
odonnell
Default AC Delco O2 sensor
I'm noticing some symptoms associated with a bad O2 sensor, and I have a AC Delco sensor (single wire output) new in package. The alternative is the expensive OEM or Bosch part.
If I splice the connector from the old sensor to the new one, will it work just as well? I just don't know if the AC Delco universal sensor supplies the same reading that the DME requires.
Thanks in advance for any info!
Old Nov 3, 2013 | 12:51 PM
Dougs951S's Avatar
Dougs951S
All narrowband o2 sensors supply a 0-1 volt signal that corresponds to a lambda value in a roughly linear fashion. I would think if you spliced it in, it would work just fine.
Old Nov 3, 2013 | 12:56 PM
odonnell's Avatar
odonnell
Excellent, thanks Doug. That'll be later this afternoon hopefully
Old Nov 3, 2013 | 06:23 PM
John_AZ's Avatar
John_AZ
Proprietoristicly Refined
If you splice it, it must not be soldered.
Explanations:
https://rennlist.com/forums/924-931-...ml#post8734617
I do not use aftermarket O2 sensors. The couple I tried did not react properly for the DME.
If you do not have strict emissions testing in TX, you should be OK.
J_AZ
