Can get rid of exhaust fumes in cabin
it is an 87. see photo, i am assuming the headers are cast... i have only had the car 3 months so who knows what has been done over the years. yesterday going home from work it about ran me out, clothes reaked of exhaust, this morning coming in, i smelled it for about 5 mins, last 15 minutes I didnt smell it. this is driving me insane.
Attachment 769971
1987 Red 944 N/A
Attachment 769971
1987 Red 944 N/A
You could jack the car up and search for leaks. Just in case you haven't seen them yet - there are threads on here that show the proper jack points or just use some ramps.
Yeah, those are cast - someone must have replaced the original ones. Do you smell it at all while idling with the hood up or does it only happen at speed (that would be more in line with what others are saying about plugging holes)? You could jack the car up and search for leaks. Just in case you haven't seen them yet - there are threads on here that show the proper jack points or just use some ramps.
1987 Red 944 N/A
There is a threaded hole that should contain a plug just ahead of the cat, could be missing. If you live in a state that does emission testing , the PO may have removed it or drilled a hole in the exhaust ahead of the cat to pass the test. It's an old trick to get an old cat to 'light up' by feeding it extra fresh air.
1 Post
This may not sound like a complete solution, but it sure beats dying of fumes in the cabin. Extend your exhaust tip. There is a large dead air space behind the car while it is travelling down the road, and exhaust can get caught in this area and get sucked into the cabin through one of many holes/seals etc. Old Datsun Z cars suffer from this, and after I replaced and sealed everything I could find, I extended the muffler tip 3 inches, and the car got 100 times better. (pointing the tip towards the ground will help as well.) It had a side benefit of the car being cleaner as the exhaust was no longer getting the back of the car dirty.
goodluck!
goodluck!
I had-have the same problem with my 87. I tyred new manifolds, sealing all
the holes I could find, new shift boot. By far the biggest improvement was
from the rear hatch. I got new hatch pins (mine were seized) and got rid of
90% of the fumes.
Thinking the rest could be gotten rid of with a side exit exhust in the back..
Steve
90% of the fumes.
Steve
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
just looking at the thread title, my first inclination would be to get suspicious about a possible cracked header.... but then, then engine would be noisy.
next suspicious area to investigate would be the overall seal at the rear hatch.
maybe line the entire hatch seals with window putty and take a short drive
and check if the situation has improved.
the hatch glass is glued to the aluminum frame - the bond fails at the top and this lets water and sometimes fumes into the car - check that. If it is coming debonded, there is an on-line FAQ on how to reseal - be sure to use both primers if you do this or it won't stick (personal experience)
Blends into the black frame nicely and it keeps the water and fumes out..
Steve
I had the same on an '88 944S. It got worse if the sunroof was open because that caused a venture sucking air through anything unsealed at the rear hatch. I tweaked around with the rear seal (pulled it off slightly and adjusted the latches to make the lid close tighter - but no so tight that it wouldn't release
... that worked for me. I also looked at why it smelt so rich as well ... it was rich on WOT and that made the problem worse ... still working on that problem
goodluck!
goodluck!
Additionally I installed the hatch pin seats from only944.com http://only944.com/partscatalog/only/hatchpinseats.html which also gave me a better seal by eliminating the vibration of the pins in the seats which keeps the seals firm against the deck. Also got rid of the annoying rattle. I can hit speed bumps now with no rattle from the hatch.
... that worked for me. I also looked at why it smelt so rich as well ... it was rich on WOT and that made the problem worse ... still working on that problem ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Glad to hear that you are making progress. Be interested to see how you get on with the rich mixture issue. I was thinking O2 sensor too. Wilks who supplied my performance chip have suggested I check the mixture setting on the DME too .. just not had the time
