Before, During, and After Plasti-Dip pictures
Glossifier, which is what I used, is opaque. The clear is matte, so both will dull your headlights.
The stuff is reversible and durable the same time, so that's the advantage. Plus it was about $25 to do the roof job, above. i'm betting it's way easier to use than paint, too. I am fairly new to spray painting and had a pretty easy time with the plasti-dip. Furthermore, over-spray is not a problem because you can rub it off. If I know I could do a good job, color-matched automotive paint with clear coat would be great.
It doesn't look bad, does it? I am planning on keeping it like this for a while. At least it's an improvement over what I had. I appreciate the input so far.
here are before and after photos of a fender on my car - I did this work in my driveway, nothing special except spray guns and a decent compressor. you can do this too.
Last edited by william_b_noble; 10-05-2013 at 03:27 PM. Reason: smaller photos so you can see what I am talking about
Plasti Dip is some neat stuff.
I did my entire 951 with 4 colors as a temporary paint job. The original color was burgundy, and in very bad condition.
I plan to remove it or do a new design over it, by the new year.
Today I got
My Custom Title
My Custom Title
From: Las Cruces NM (NMSU) / Fountain Hills AZ (home)
I'm confused about that picture, did you spray plastidip over the repair or real paint?
I believe he's saying it's real paint.
I bought a quart of Steingrau basecoat from the auto paint dealer, and had him put it in 16-oz spray cans. (These are a high quality spray can) I used it on my lower valance with a coat of rattle-can clearcoat (from same dealer) over the basecoat. Total cost was almost $200, but I have 2 cans of basecoat left. It doesn't spoil.
Team Owner
From: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
Jesus guys. pleasssssssseeee go and sand some cars at a body shop.
the senior guru, Mr. Noble is absolutely right....
and the body prep for my paint ?
same... just hacking in the back yard...
after the front end re-design, the rear valence took about 12 hours to get down to the primer and the bottom of the surface cracks...
and where you do that ?? on the picnic table, of course...
and a few hours of cleaning and final prep at the shop prior to the big spray.
1987 Red 944 N/A *** NOTE- I probably posted from my iPad, please excuse any typos, bad punctuation or odd grammar, if it is unreadable, it probably was posted from my iPhone.
Team Owner
thanks a million for that comment.
it broke the bank, but it really is a better designed LS7, imo.
and with it now done, the variocam will likely be driving it's last on 22 or 23 November
my work schedule, Eric's shop and the fiftieth anniversary of the coup d'état all sort of fell into place...
i'll be in Dealey with my fellow researchers.
and then drop off the car.
I'm looking forward to the outcome.
