I am afraid to look - 944S balance belt in a ball
#31
I love the Porsche mystique too, but to offer the other side of the story, 95% of problems are user-error. And over-engineered is just a compliment to one of the best-handling front-engine cars ever. That's right, that's what Porsche did to the 944.
#32
Oh I can definitely see a jammed cog belt stopping an engine - especially how this cog belt became uniquely enwrapped with the the T-belt. When the roller failed and the bolt unscrewed the balance belt sprung toward the passengers side and catapulted the roller. The the balance belt got sucked into the the lower t-belt cog pulley in between the cog and the t-belt. As the engine continued to turn it reached the end of the balance belts' slack causing the t-belt to jam immediately. Since the engine wasn't idling more than 700 RPM it's ability to produce any real HP for load the engine cut. The clunk I heard was likely the roller being jammed and the belt balling up.
The lesson is I am a butt head for not replacing the rollers no matter how "good" they looked. The other lesson is there is such a thing as a second chance and I am not looking a gift horse in the mouth and will be replacing the rollers. Stupid @** rookie mistake - oh well...
Pete
Pete
#33
That engine looks pretty rusty, plus that roller looks pretty worn, so all of a sudden you have an engine that is not fit for torque specs, and that includes how tight the BS truly needs to be. Seems to me like you need fresh parts to do it right.
And I totally agree on the user error:\ I have proven that too true in the recent 48 hours. I consider myself very lucky I am getting a second chance with this car.
#34
Basic Sponsor
Hoping all comes back together again soon and you fire her up and all is fine. Update when you can.
Mark/Pelican Parts
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
#35
If you're lucky enough to have escaped bent valves, I would replace the t-belt again with all new rollers. That t-belt took quite a bit of stress stopping the engine. It is not designed to do that!
#37
Thanks for the advice. I would love to know why after all of the t-belt jobs and updates someone hasn't fabbed some replacements with higher quality bearings. The belt cog gears don't wear out their bearings do. And if I were ambitious enough I'd find a source for those bearings and press new ones in. My point is that a higher quality bearings and materials would easily last 80K miles. Replacing the belts is one thing, but the rest of the parts including the water pump should go the distance. Heck cheaper marquees go the distance why cant we make these great cars do the same? Not that I have spent a lot of time studying the 944 engine, but I have to wonder why the balance shafts are not gear driven internally - maybe not possible, but... Anyway more to come later this week.
#42
Just ordered a ContiTech kit with five rollers and two belts. Jeeze I can't wait to get this thing out of my hair so I can start on the real 944 project.
#43
You can't press new bearings in, but you could probably machine the center part and CNC a new cog gear that would press onto a bearing - and your cost would be around $500 rather than $30.
#45
