Fuel Damper Compression Fitting Leak
Old 12-28-2001, 11:04 PM
David Salama
David Salama's Avatar
Post
SM,
I took a hack saw to the lip / edge of the compression fittings to get it started. Then I took a vise grip or plier to twist and peel off the crimped fitting. You probably don't want to use any power tools since you are working near fuel. Be careful and good luck.
Old 01-01-2002, 11:13 PM
David Salama
Post
Here are some pictures of my new braided stainless steel fuel lines.
Old 01-01-2002, 11:54 PM
Perry 951
Perry 951's Avatar
Post
The only diffrence from the SFR fuel lines and the pics posted above are the fittings.
I will be first to say that if I had the stock lines on my 951 when it caught fire, I would have lost a lot more than I did. The lines did leak after it burned for a while, but that is expected from the heat expanding the rubber. The return started to leak at the firewall and allowed a little fuel to spill out causing a good poof of flame. I probably did not have the clamp tight enough.
As far as the rest of the line, it was charred and that was it. Both lines still hold pressure. Well worth the money. (or you can make your own for $60 and deal with cutting the braids and hope you don't ruin it!)
Old 01-02-2002, 02:40 AM
sm
sm's Avatar
Post
thanks David and Perry...
i'll be receiving the SFR fuel lines tomorrow or thurs. i can't wait to get the car on the road again. i'll be working in the 25 degree weather, but i don't care. just want to drive the car! i'll try to post pics after it is done.
thanks,
sm
Quick Reply: Fuel Damper Compression Fitting Leak
