Source for OEM caster blocks
Hi,
Does anyone have an alternate source for OEM caster blocks? The price for new ones have gone up and are now $197/each from the dealer! Even with my PCA discount, it will still cost around $350/pair. Used ones are out as they are likely not any better than what is on my car and the part has been updated many times over the years.
TIA
Bill
86 944 NA
TIA
Bill
86 944 NA
Lifetime Member
Lifetime Member
Originally posted by Bill K:
<STRONG>
Does anyone have an alternate source for OEM caster blocks? The price for new ones have gone up and are now $197/each from the dealer!</STRONG>
<STRONG>
Hi Tom,
I replaced those on my 968 back in 1998 also and paid about $100/each. I'll try the part numbers you posted - maybe they were quoting me the M030 parts.
Thanks!
Bill
Thanks!
Bill
Former Sponsor
Hmmm. My wrench just replaced mine with the updated parts (like Tom described, and thanks to him for alerting me they existed). He only charged me like $40 each. Don't know where he sourced them from, but I do know he gets alot of stuff from Zim's.
I just checked with Suncoast Porsche and the prices are about $50/each as Tom stated. I guess my local dealer either has a larger profit margin or looked up the wrong part.
Thanks for all your help.
Bill
Bill
You can reuse the caster bushing bolts (to the chassis). The M12 nuts on either side of the caster eccentric are "one-time-use" locking nuts. Your choice if they need replacement... I would assume most folks do not replace them, right or wrong.
If you have a good metric source nearby, they are M12x1.5 nuts (grade 8 or better). I suppose you could use nylock bolts instead.
If you want the porsche part, it should be 900.910.115.02 or N.021.131.1.
Torques for your new stuff:
- caster block bolts - 34ftlbs
- caster eccentric - 63 ftlbs.
Good Luck!
Good Luck!
