Fog lights
So I have a short somewhere on the passenger side so every couple weeks I blow a fuse. Then tonight my left fog light went out. I've never done a fog, but am I correct in saying I need to get the whole assembly? Or just a bulb? I want to make sure before I take it apart and possibly screw it up..
Someone more knowledgeable will tune in, but I am almost sure you only replace the bulb. What bulb, exactly, may be the next question.
Here are a link and some pictures to provide guidance.
http://www.autoatlanta.com/porsche-p...erior-Lighting
You have to remove the front part of the assembly. The bulb is removed from the rear of the reflector housing.
On mine, there were 2 screws in the little plastic end cap that cover the gaps on each side. Remove them, and you will have access to four bolts that hold the glass to the bucket. Remove them and the part in the upper left photo can be pulled out for access to the bulb.
