DME relay question - no fuel
Old 09-05-2013, 12:22 PM
NSA
NSA's Avatar
Originally Posted by 931guru
I guess that this is your first Porsche...
It's my second. How is this worth $30?
Old 09-05-2013, 02:23 PM
jpk
jpk's Avatar
It's worth it when you just plug it into your relay board and the car runs. There's technically no reason you can't replace it with a pair of generic $3 relays and make up the wiring harness to make it work. It'll just be a PIA to mount it reliably and package everything.
Old 09-06-2013, 12:59 AM
william_b_noble
william_b_noble's Avatar
also, the DME is available widely for closer to $18, and if you pick up a few bad ones and fix them, they are free forever.
Old 09-07-2013, 04:08 PM
NSA
NSA's Avatar
My problem is that I have 12v coming out of the DME into pin 85b, where the DME relay is expecting to see ground. Any idea what condition the DME thinks is happening for it to do this? My guess is it is receiving a signal saying the engine is revolving at <300rpm, or a diode has gone in the DME, allowing power to flow where it shouldn't. Bad speed sensor maybe?
Help gratefully received.
Quick Reply: DME relay question - no fuel
