Help please. Brakes.
I've bled the system after installing a BMc and I'm having stiff pedal feel but no grab of the brakes. Not sure where to go from here.
Help appreciated.
Help appreciated.
I was told something similar. Get it on blocks and then see if I can spin any of the wheels with the brakes applied. Perhaps, if I get bad grip on a wheel after that test, I would pull the caliper and check it out?
As a quick test, have you tried really slamming on the brake (while stopped)? Try repetitively putting all your muscle into it. This could free the piston.
It just seems like the fluid isn't able to flow in the system.
Exactly, the wheel should be un-turnable even with slight braking. If you can turn the wheel by hand while braking, your probably having a problem with your piston. It might be frozen. At this point your next step is to remove the caliper and see why the pads aren't being pushed against the disc. If the piston is free, there must be another reason why the fluid isn't pushing it.
Thanks much for the direction, ill update.
New master cyl? is the push rod through the center of the booster in the correct place? when I did the master on my car it fell out and I thought it sat loosely in the booster, I was wrong. Got it together and the pedal was stiff but I had no brakes. Took it back apart and seated it in its grooves correctly, the push rod stayed in place and centered correct and then the brakes worked great.
Are you getting power brakes? Might be something wrong with the booster?
When driving and you hit the brakes does the car pull? We're any calipers left hanging on the brake line or were the lines squeezed?
Keep in mind, if you pull the calipers and push on the brake pedal, expect the piston to blow out of the caliper. Get a large pan under it because there'll be lots of brake fluid on the floor. And keep the pads out of it so they don't get soaked with brake fluid.
Thanks for the tip. If I gotta pull the calipers, I'll remember that.
Proprietoristicly Refined
NM'87
If you still cannot get a firm brake pedal you have an air pocket in the BMC.
Did you eventually do a bench bleed on the BMC?
https://rennlist.com/forums/924-931-...nt-w-pics.html
Do you have a firm clutch pedal?
J_AZ
J_AZ
NM'87
J_AZ
J_AZ
I did not bleed the cylinder. My justification for that is two fold. 1. I stripped one of the hard line connectors, and had it repaired enough to finally get it screwed in and then fit the bmc in place. This process would have caused fluid to come out of the bmc all over the place, and air could have very easily gotten back in. 2. I assumed that running enough fluid through the cylinder while bleeding the brakes, with some light tapping would have freed up or burst any air bubbles in the bmc. I might be taking the bmc out to seat the piston, so may be I'll bleed the bmc @ the bmc (by removing the hard line connector to the rear bias valve and bleeding from there). Someone told me that works too.
I know how to turn a wrench, and have a general road map of how a car works/operates. I have little to no experience with this stuff, so you guys are truly helpful. I appreciate it.
The booster is vacuum assisted, if there is no vacuum getting to the master it will have no power assist breaking. There is also a one way check valve I believe at the booster
Is there a step I am missing?
The initial symptoms (to remind everyone), was a pedal that would travel low and grab the brakes, but would then release the brakes as the pedal faded. We were told a leak @ the bmc, so we replaced it (we found the possible culprit in a leaky o-ring on the old bmc piston).
I would suggest not removing the calipers just to see if you have a frozen caliper. What I would do is get a clear hose and attach it to the right rear bleeder valve and run it into a pan. Then have someone push the pedal down as you open the valve. If the pedal drops you have fluid travel to that caliper. If not go to the next caliper (left rear) and repeat, then the right front and left front. Just like a bleeding sequence, but this will tell you if it is in fact the calipers or there is a blocked line or master cylinder. If you get pedal travel through only one, two, or three lines, you may have a blocked line or frozen caliper or piston. The frozen piston isn't very common in any vehicle, its usually rust/corrosion on the caliper slide pins that makes a caliper stick. I would recommend cleaning and lubricating caliper slides whenever the pads are changed and always flush the fluid at least once a year on a daily driver and more frequently on cars that run high brake temps (racing etc etc)
I have also seen blockage in old hydraulic flexible hoses and on modern vehicles inside the check valves.
If your pedal does travel to the floor when all four bleeders are opened one at a time, then you more than likely have a brake booster problem. If the old master cylinder was leaking at the back seal, then the fluid more than likely damaged the booster. Sometimes at the brake shop I used to manage we could suck the fluid out depending on the type of booster, but its always better to replace with a new one.
Someone posted to make sure the pushrod is lined up correctly. I would definitely check that before going through the bleed sequence.
I try to keep this short, but there is so much information about brakes that can be helpful to someone. Trade knowledge is the best information a guy can have in automotive.
