951 Oil Pressure Indicator
Hi everyone (first post here ),
What is the "normal" oil pressure you get on the 951´s gauge?, went to see one today that showed about 1-2 at idle, and 5 while driving, is that ok? thanks,
[ 10-06-2001: Message edited by: Nurburgring ]
6th Gear
Hi - this is quite normal once the engine is warm - as long as you're seeing 4/5 under normal driving all should be well.
IanS
IanS
Originally posted by Nurburgring:
<STRONG>Hi everyone (first post here ),
[ 10-06-2001: Message edited by: Nurburgring ]</STRONG>
Actually I would consiter that a bit low. My car pulls 3.5-4 at idle with 20-50 oil. I do have the late oil pressure regulator and I think that helps. I have heard the early regulator are a lower.
