What oil should I be running?
5W-30 High Mileage, 10W-30 High Mileage, 10W-40 High Mileage
900 PPM P, 1000 PPM Zn
0W-40, 5W-50
1000 PPM P, 1100 PPM Zn
15W-50
1200 PPM P, 1300 PPM Zn
The 15W-50 has 300 ppm Zn more than the HM and 200 ppm Zn more than the 0W-40.
Bear in mind guys, it’s not just the ZDDP ppm but also the actual weight of the oil which provides the all important film strength. You could have equal parts ZDDP in a 0w/40 and a 20w/50 and the 20w/50 is going to offer better protection under load/heat. If you live in regions where the Owner’s manual prescribes a lower than 20w/50 then by all means go by the factory recommendations.
Correct me if I'm wrong, but last time I looked at the Mobil product guide, that was not the case.
0W-40, 5W-50
15W-50
0W-40, 5W-50
15W-50
porsche approved a40 oil list
I rely on the A40 oil list. Why should I know better than the Porsche engineers? Here in Germany you can run your car hours and hours fullspeed over the German Autobahn (no speedlimit). So I did across Germany with Mobil1. So far the engine seems to be in good shape.
This type of engine wear can occur over a prolonged period of time.
While I respect the factory recommendation, I also question the "one size fits all" approach particularly when it concerns the last century engines. We know there are specific oils not listed that have a a proven margin of safety for the older cars.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
but, let us not get too carried away, lest we forget: the real question
(in anticipation of your next #2 rod-bearing failure) is...
what engine should i be running?
because there are
1. better lubricant choices out there today. a modern, synthetic 10w60 will blow the doors off any lubricant product available in the 1980s to protect the Porsche 944's fragile bearings at Autobahn speeds.
2. the premium wide-viscosity range synthetics developed in the last few years do not rely on nearly as much trickery (as conventional oils or early synthetics) to achieve 15~20 weight viscosity rating at operating temperature (that's right, your favorite 15w~20w50 Amsoils, Deep Purple, or Redline's viscosity rating is about 18.5~20 at operating temperature, while M1 0w50 is just slightly lower. they do it with advanced polymers that were not fully developed in 1985, *and minimum viscosity modifier.
3. the technology offered in synthetic oils blows the doors of conventional oils in the context of cold weather startup....
just to clarify, when it says track use only, it would be more accurate to caution anyone running a catalytic converter that, when using this oil, you should do it with the possibility of reduced life of your catalytic converter in mind.... this is the best motor oil for our cars, period. why?
1. it's ~ 98 % as thick as regular 15w50 at running temp.
2. will beat any 50 weight oil on earth on the dyno, because it's the damned slipperiest stuff you can run in your engine, period.
(the next person to dyno a 944T should do it with 20w50 and then change to 0w50;
don't be surprised when you see a 10~15 hp gain). http://www.mobiloil.com/USA-English/...ing_0W-50.aspx
3. saves gas on the street with zero compromises, nearly paying for itself....
4. it's the best winter oil for our cars. will flow well at startup down to about 0° F... but,
5. as a maximum protection oil, it's probably the best year round oil as well, as it flows better at 70° F startup on a summer morning than anything that offers maximum protection at running temp, as it has the widest viscosity rating of any oil suitable for a Porsche 4 cylinder engine *(along with 5w50 and 10w60 synthetics).
6. only the minimum of viscosity modifier *with the result being an extremely long-life oil (where the viscosity modifiers contained in your conventional oils break down or are burned off as soon as early as 1000~1500 miles.... and why this is precisely why I consider conventional oils to be more expensive than synthetics.... after just a couple of thousand miles, they're effectively reduced to straight 40 or 50 weight oils in our hard running 944s and 968s).
7. it's stable all the way to 500° F. *(the only oil ever produced to achieve this). not that any turbo or non-turbo engine for the street will ever get near there....
8. adds longer life to turbos, turbo engines and non-turbo engines, having 1850 ppm of zddp...
in the table below I used the thickest 15w50 grade synthetic available: Redline....
notice how at operating temp, their 20w50 oil is only fractions of a % thicker.
oil/SAE grade ................... visc @ 104° F............................. visc @ running temp / 212°F
Mobil 1 20w50 V-Twin............. 172 ..............................................,. 20.8
Redline 20w50 ....................... 148 ............................................,.. 19.8
Redline 15w50 ....................... 138 ............................................... 19.6
Mobil 1 15w50 ....................... 125 ............................................... 18
Mobil 1 5w50 Rally Oil ............. 108 ............................................... 17.5
Mobil 1 0w50 Racing Oil ........... 100 ............................................... 17.2
Mobil 1 10w40 ......................... 96 ................................................ 14.7
Mobil 1 0w40 ........................... 75 ................................................ 13.5
with the V-twin oil being so thick at startup I would think it best to avoid using it at 100% mix.
0W-40, 5W-50
15W-50
0W-40, 5W-50
15W-50
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
Team Owner
Why is synthetic oil better?
Synthetic oil is better for many reasons. First of all, most motor oils have viscosity modifiers added to them to achieve multi-weight ratings (such as 10w30, 20w50, etc.). Since true synthetic oils are produced in a lab, they do not require viscosity modifiers. Over time, viscosity modifiers break down and produce sludge. You may have noticed that over the years, manufacturers have started to use thinner and thinner oils in automobiles. This is partially due to the fact that thinner oils require less viscosity modifiers and thus will break down less. After a duration (it would vary amongst oil brand and type), oils such as 10w40 break down and become a 10w20 (as a hypothetical example). If oil is left in a car long enough, it will become the base winter weight only. ie: 20w50 left in a car too long will eventually become a 20w20 or "straight 20".
Another reason that synthetic oils are better is because there is much more congruency between the oil molecules. A good way to exemplify this is to imagine a concrete mixer full of *****. If you have a mixer full of bowling *****, tennis *****, golf *****, and basketballs, they will not flow together as easily. This would be akin to conventional oil. Synthetic oil would be more like a concrete mixer full of nothing but tennis *****. All of the molecules are the same size and thus there is less friction and they bond together much more easily. You can see this by tilting a bottle of synthetic oil - the oil will form a film and stick to the side of the bottle much, much longer than conventional oil.
The leading cause of engine failure is what is commonly called a "dry start condition." When you first start your engine, you may hear a tapping from your valvetrain. This is due to the fact that it takes time for the oil to reach your valves so they are running dry for a small duration. As you can see from my last paragraph, the molecular congruency of synthetic oils would make it so that oil will "stick" to the valve-train much longer than conventional oil, reducing (and sometimes even eliminating) dry starts.
Synthetic oils can be made to achieve multi-weight ratings that would be impossible without lab production. This is important for exotic cars and German automobiles that require a very low viscosity during starting and a high viscosity during normal operation. Examples of this are 0w40 and 5w40 oils.
A caveat to all of this is that, unfortunately, most synthetic oils in North America are not true synthetics. No motor oil is purely synthetic, because pure synthetic oils are not compatible with automotive seals and are only good in industrial applications; however, some brands purify the sulfur out of conventional oil and label it as synthetic. This is legal in North America, but illegal in Europe. Most synthetic brands are filtered conventional oil.
I admit it; I've been putting 12~14 k miles after each oil change for over 5 years now... since I got my 968, I've changed the oil (thin winter oil/thick summer method) about every 6~7 months on average with a single filter swap at the half-way point.... and seen no unusual wear to my engine whatsoever after more than 180 miles on the clock.
Stop Changing Your Oil !!
Breaking the 3,000-Mile Habit
Oil chemistry and engine technology have evolved tremendously in recent years, but you'd never know it from the quick-change behavior of American car owners. Driven by an outdated 3,000-mile oil change commandment, they are unnecessarily spending millions of dollars and spilling an ocean of contaminated waste oil.
The majority of automakers today call for oil changes at either 7,500 or 10,000 miles, and the interval can go as high as 15,000 miles in some cars. Yet this wasteful cycle continues largely because the automotive service industry, while fully aware of the technological advances, continues to preach the 3,000-mile gospel as a way to keep the service bays busy. As a result, even the most cautious owners are dumping their engine oil twice as often as their service manuals recommend.
After interviews with oil experts, mechanics and automakers, one thing is clear: The 3,000-mile oil change is a myth that should be laid to rest. Failing to heed the service interval in your owner's manual wastes oil and money, while compounding the environmental impact of illicit waste-oil dumping.
Scared Into Needless Service
Part of the blame for this over-servicing lies in our insecurities about increasingly complicated engines that are all but inaccessible to the average driver. Pop open the hood of a modern car, and a mass of plastic covers wall off the engine. On some vehicles, the only thing an owner can easily access is the oil cap.
"Vehicles are so sophisticated that oil is one of the last things that customers can have a direct influence over," said Matt Snider, project engineer in GM's Fuels and Lubricants Group. "There's maybe some feeling that they're taking care of their vehicle if they change their oil more often."
The 3,000-mile myth is also promoted by the quick-lube industry's "convenient reminder" windshield sticker. It is a surprisingly effective tool that prompts us to continue following a dictate that our fathers (or grandfathers) drummed into our heads: It's your duty to change your oil every 3,000 miles — or your car will pay the price. But as former service advisor David Langness put it, the 3,000-mile oil change is "a marketing tactic that dealers use to get you into the service bay on a regular basis. Unless you go to the drag strip on weekends, you don't need it."
Car dealers' service departments are also guilty of incorrectly listing the mileage for the next oil change. We've seen them recommend a 3,000-mile oil change on a car with a 10,000-mile interval and also list a 5,000-mile recommendation on a car that has a variable oil change schedule.
Because busy car owners seldom read their owner's manuals, most have no idea of the actual oil change interval for their cars. And so they blindly follow the windshield reminder sticker, whether it's an accurate indicator of the need for an oil change or not. "I just go by the sticker in the windshield," one well-to-do, educated Denver Lexus owner said. "Otherwise, how would I know when to change it?"
A career Navy mechanic who bought an Edmunds.com long-term car just shrugged when he was told that the vehicle had safely gone 13,000 miles between oil changes. "I'll just keep changing the oil every 5,000 miles," he said. "It's worked well for me in the past."
Our oil-change addiction also comes from the erroneous argument that nearly all cars should be serviced under the "severe" schedule found in the owner's manual. In fact, a quiz on the Web site maintained by Jiffy Lube International Inc. (owned by petrochemical giant Shell Oil Company) recommends the severe maintenance schedule for virtually every kind of driving pattern.
The argument that most people drive under severe conditions is losing its footing, however. A number of automakers, including Ford and GM, have contacted Edmunds data editors to request that the maintenance section of Edmunds' site substitute the normal maintenance schedule for the severe schedule that had been displayed.
About the only ones that really need a 3,000-mile oil change are the quick-lube outlets and dealership service departments. In their internal industry communications, they're frank about how oil changes bring in customers. "Many people...know when to have their oil changed but don't pay that much attention to it," said an article in the National Oil and Lube News online newsletter. "Take advantage of that by using a window sticker system [and] customers will be making their way back to you in a few short months."
Another National Oil and Lube News article tied the frequency of oil changes to success in pushing related products and services. For a midsize SUV, the stepped-up oil change intervals will bring in $1,800 over the life of the car, the article says. "A few extra services [or oil changes] can go a long way toward increasing the amount of money a customer will spend during the lifespan we estimated here," the article concludes.
Today's Oil Goes the Distance
While the car-servicing industry is clear about its reasons for believing in the 3,000-mile oil change, customers cling to it only because they're largely unaware of advances in automotive technology. Among 2013 models, the majority of automakers call for oil changes at either 7,500 or 10,000 miles based on a normal service schedule, more than double the traditional 3,000-mile interval. The longest oil change interval is 15,000 miles for all Jaguar vehicles. The shortest oil change interval is 5,000 miles in some Hyundai and Kia models with turbo engines and Toyota vehicles that call for non-synthetic oil. Toyota has been shifting its fleet to 10,000-mile oil change intervals using synthetic oil.
"Oil has changed quite a bit and most of that isn't transparent to the average consuming public," said Robert Sutherland, principal scientist at Pennzoil Passenger Car Engine Lubricants.
Synthetic oils, such as the popular Mobil 1, are stretching oil change intervals, leaving the 3,000-mile mark in the dust. "The great majority of new vehicles today have a recommended oil change interval greater than 3,000 miles," said Mobil spokeswoman Kristen A. Hellmer. The company's most advanced synthetic product (Mobil 1 Extended Performance) is guaranteed for 15,000 miles.
Today's longer oil change intervals are due to:
•Improved "robustness" of today's oils, with their ability to protect engines from wear and heat and still deliver good fuel economy with low emissions
•More automakers using synthetic oil
•Tighter tolerances (the gap between metal moving parts) of modern engines
•The introduction of oil life monitoring systems, which notify the driver when an oil change is required and are based on the way the car is driven and the conditions it encounters. Sixteen of 34 carmakers now use oil life monitoring systems in their 2013 model-year vehicles, including all three domestic automakers. That represents a majority of the vehicles sold in the U.S.
One GM car Edmunds drove went 13,000 miles before the monitoring system indicated the need for an oil change. We sent a sample of that oil to a lab for analysis. The results showed that the oil could have safely delivered at least another 2,000 miles of service.
Oil experts and car manufacturers are solidly on the side of the less-frequent oil changes that these formulation changes make possible. "If customers always just stayed with the 3,000-mile recommendation, there'd be these great strides in the robustness of oil that oil companies have made [that] wouldn't be utilized," said GM's Matt Snider. Consumers, he said, would be "throwing away good oil."
Chris Risdon, a product education specialist for Toyota agreed, adding that oil technology advances that permit fewer changes are a tool to protect the environment. "If you're doing it half as much, that's 5 quarts of oil times 1.7 million vehicles a year ? that's a tremendous amount of waste oil that's not being circulated into the environment."
Waste oil is a problem exacerbated by too-frequent oil changes, according to the California Integrated Waste Management Board, which has campaigned against the 3,000-mile dictate. The agency says that 153.5 million gallons of used oil is generated in California annually, but only 59 percent of it is recycled.
Our Fit Gets Taken for a Ride
Before the initial publication of this article in August 2010, we took a 2007 Honda Fit to Jiffy Lube for an oil change to see what might happen to the average car owner. The car had an oil life monitoring system, and the system had recommended the past two oil change intervals at 5,500 miles and 7,600 miles on non-synthetic oil. In both cases, an engine oil analysis revealed that the oil could have provided at least another 2,000 miles of service.
On this occasion, we told the Jiffy Lube service advisor we were considering synthetic Mobil 1 because we heard it could extend our oil change intervals. The service advisor said the synthetic oil could enable the Fit to go 4,000 or 5,000 miles before the oil "burned out." The Mobil 1 oil change had a price tag of $92.39. The technician also took the opportunity to upsell us, recommending a cabin air filter for $49.99. The total for our visit, after a $15 coupon, was $132.72.
When the car was returned to us, the sticker in the window called for an oil change in 3,000 miles, not the 4,000 or 5,000 miles the service advisor had promised.
If we had been foolish enough to follow Jiffy Lube's 3,000-mile change schedule (which is essentially the advice given by all quick oil change outlets and dealership service departments), the Fit would have undergone four unnecessary oil changes per year (assuming 15,000 miles per year of driving), wasting $369 and 15.2 quarts of perfectly good oil. Over five years of the car's life and 60,000 miles of driving, this would have amounted to $1,847 and 125 quarts of wasted oil. This does not include other "upselling" items at each visit, such as cabin air filters.
Defending the 3,000-Mile Interval
The quick oil change industry justifies its perpetuation of the 3,000-mile standard by saying that most people drive under "severe" conditions. Jiffy Lube's quiz, mentioned earlier in this article, is one example of how that notion is reinforced in drivers' minds. An oil change company representative said the 3,000-mile recommendation is meant to be just that — a recommendation.
In 2010, Scott Cudini, innovations manager for Jiffy Lube, repeatedly called the 3,000-mile interval a good "fallback position," meant to be a guideline but not a hard-and-fast rule. He added that Jiffy Lube technicians would initiate a "dialogue" with customers about the oil change intervals that apply specifically to their cars.
"In most cases," Cudini said, "even if customers' cars have been plastered with that 3,000-mile sticker, they may have been told by the service advisor that, 'By the way, Sir/Madam, your interval is 5,500 miles.'" Based on our experience with the Honda Fit at Jiffy Lube, as well as at other quick-change outlets, technicians rarely initiate dialogues that could provide accurate information about oil change intervals. In fact, according to a Jiffy Lube spokesperson, the system for supplying technicians with answers only gives them information from a vehicle's severe schedule.
Turning Over a New Leaf?
Nearly 10 months after we first published this article, Jiffy Lube announced that it was undertaking a "new approach to oil changes that helps customers access and understand their vehicle manufacturer's recommendations, and choose the oil change schedule that is best for their needs."
We witnessed Jiffy Lube's "new approach" firsthand when we took one of our long-term cars in for an oil change in March 2013. When the sales representative approached us, we told him we didn't know if we needed an oil change or not. We said we weren't sure what the intervals were.
The technician looked up the oil change interval on his computer and said it was either 5,000 or 7,500 miles depending on how we drove the car. This, of course, is the traditional severe-versus-normal driving schedule. In the past, quick-change oil shops have tried to get everyone on the severe schedule because it means more business for them. But now, the technician said, "We can set the sticker for whatever you decide." This is just what we wanted to hear. No more 3,000-mile intervals glaring at us from the little sticker in the corner of the window.
But this was only a sample size of one. And even if all Jiffy Lube locations are onboard with the new approach, there are still hundreds of quick-lube shops that do things the old-fashioned way. Their deep fallback argument in favor of frequent oil changes is that they are a hedge against trouble. You can't hurt your engine by changing your oil too often, so doesn't that imply that it might actually help it? Well, no.
Steve Mazor, manager of American Automobile Association's Research Center, said that more-frequent-than-necessary oil changes will not "gain any additional life for your engine or any improved fuel economy." He added, "In reality it will make little or no difference to the performance of the vehicle."
The Right Time To Change Your Oil
So where does this leave the car owner who was raised on the perceived wisdom of the 3,000-mile oil change? For a full discussion, your next stop should be our related article, "When Should You Change Your Oil?," which will save you hundreds of dollars over the next few years and fully protect your car and its warranty, while limiting the use of a natural resource.
The short answer, meanwhile, is to consult your service manual or Edmunds' maintenance section to learn your car's actual oil change schedule. If your car has an oil life monitoring system, don't try to second-guess it. Understand how it works and follow its guidelines. To probe more deeply into this subject, consider sending a sample of the oil from your next oil change to a lab such as Blackstone Laboratories, for an inexpensive analysis. Our last suggestion? Rip that sticker off your windshield
@ odurandina
hm, lots of text.
I can provide you to another sort of information. From my point of view very interesting and worth reading it, indeed.
Here's the link
http://www.ferrarichat.com/forum/faq...=haas_articles
aditionally attached the PDF
hm, lots of text.
Here's the link
Team Owner
evidently you haven't seen my 500+ posts on who was responsible for the JFK hit.
bingo; especially in the context of those of you running turbines, this is precisely why I posted that table above, proving once and for all, the 0w50 oil while being almost thin enough @ startup to flow properly through the crankshaft on those cold mornings (0w40 is still the clear winner), it is thick enough in spades to make it all the way to the highest operating temperatures your engine will see:
*and this point of view is bolstered in the quote below (from the article you posted)....
Here's the link
Here's the link
Oils are divided into grades (not weights) such as a 20, 30 or 40 grade oils. This represents the viscosity range at operating temperature. But it is NOT the actual viscosity as we shall see. The issue is that viscosity is temperature dependent. Let’s look at a 30 grade oil and how the viscosity of this grade of oil varies with temperature:
30 grade oil (often referred to as a 30 “weight” oil):
Temperature ( F )....Thickness
302...........................3
212..........................10
104..........................100
32..........................250 (rough estimate)
The automotive designers usually call for their engines to run at 212 F oil and water temperature with an oil thickness of 10.
This is the viscosity of the oil, not the weight or grade as labeled on the oil can. I want to stay away from those numbers as they are confusing. We are talking about oil thickness, not oil can labeling. This will be discussed later. Forget the numbers on that oil can for now. We are only discussing the thickness of the oil that the engine requires during normal operating conditions.
The engine is designed to run at 212 F at all external temperatures from Alaska to Florida. You can get in your car in Florida in September and drive zig-zag to Alaska arriving in November. The best thing for your engine would be that it was never turned off, you simply kept driving day and night. The oil thickness would be uniform, it would always be 10. In a perfect world the oil thickness would be 10 at all times and all temperatures.
Mobil 1 Racing 0W-50
@ odurandina
Mobil 1 Racing 0W-50 seems to be a very good choice. Since my car doesn't have a catalytic converter it should be no problem at all. Remarkable also the HTHS Viscosity of 3.8, that's really good.
I'm looking for good source for that oil.
Let me be the devil's advocate:
How about for us who do not track, or redline our vehicles and drive rather tame and put low mileage on?
That's what prompted me to go with 15w40 synthetic. But maybe next oil change I'll try different like 0w50 and see.
