944 and 951 interchangable parts
Can the A/C compressor from a 944 be used on a 951 engine?and what about the alternator, are they the same?
also i am curious weather the pressure plate and throw out bearing are different in the clutches. I know you have to use different clutches for 944 and 951 but are any of the clutch parts interchangable?
From Griffiths:
All 85.5+ alternators are also the same.
From 1985.5 onward Porsche used a smaller swash-plate multi-piston driven Nippondenso having 4 mounting ears. This same unit is used on the 924s. The clutch pulley is a 6 groove serpentine (multi-rib).
so technically could the alternator from a 944 be used?will it ruin anything?or will it just be slower and crappier?
and also whats up with the clutch?what can i use?this is important cuz clutch is friggin $$$$
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Originally posted by Thaddeus:
<STRONG>No, Tabor, they only look the same to the casual observer. The alternator in the 951 is much better and makes the car faster.
Thaddeus</STRONG>
Thaddeus</STRONG>
I'd also look into silver spark plugs and a 951 head gasket. Painting the engine block with special formula VHT paint will also give you an extra 10hp or so.
-Mark 86 944 NA
Deer Slayer
Good point, Mark. It also doesn't hurt to run KaleCo's engine cleaner through to lose the weight of all the sludgey bits. Use the special 951-approved formulation for that extra edge in the 1/4 mile.
Thaddeus
Thaddeus
Originally posted by Andre:
<STRONG>so technically could the alternator from a 944 be used?will it ruin anything?or will it just be slower and crappier?
</STRONG>
</STRONG>
I would look for or talk to someone with a PET to check about part numbers listed for the two cars, the parts these guys are talking about are special performance parts that help me gain 500+ hp. I bought the O pipe to spool the turbo up faster and found that it has no lost boost and the piston return springs.......O...MY .....GOD!!! the power!!
Tabor,
After reviewing your last statement...
Its time for you to have your implanted brain-microprocessor turned to "normal-mode." Aso while your at it you probably need to replace other bionic wear items. You are suffering from information-regurgitation-overload-us. Its a common problem with cyborgs.
