Late Strut Top Mounts on an 86 Turbo?
Old 08-14-2013 | 11:40 PM
MAGK944's Avatar
MAGK944
Default Late Strut Top Mounts on an 86 Turbo?
Any issues? I test fitted and they bolt right up, just concerned if the angle of the bearing being slightly different may cause problems. They sure look like a much better mount that the early ones I have fitted.
Old 08-14-2013 | 11:50 PM
Dougs951S's Avatar
Dougs951S
They are totally swappable, and compensated for when doing the alignment. I've used both early mounts on a late car, and late mounts on an early car. Its worth noting that if you are using early mounts on a 85.5+ car you will need to drill a hole in the mounting flange to fit the centering pin that is on the body.
btw I am currently running VW fox mounts on my car, they were ~14 dollars a piece and I like them.
http://www.partsgeek.com/catalog/198...rut_mount.html
Old 08-14-2013 | 11:51 PM
SkipG's Avatar
SkipG
4th Gear
They are completely compatible, but beware they are not as easy to refurbish. The 83-86 have a replaceable strut mount rubber + bearing assembly that's less than $100/ea. No such luck for the 87+. If you have a late set that are in good shape and the bearings are good, then probably an upgrade. Otherwise, if you had to buy, skip it.
Good luck!
SkipG
Quick Reply: Late Strut Top Mounts on an 86 Turbo?
