What is this thing, and where is it supposed to be attached?
Deer Slayer
There is a metal tube, 1/2 inch diameter, that comes up on the passenger side of the engine bay back by the firewall. It has a cap on it that is held on with a clamp. It also has a metal strap coming off at an odd angle... in profile it is almost the shape of a collapsed windsock. It runs back under the car and I can't see where it attaches. It is not attached to anything, so the end of the tube wobbles around. UNacceptable. ![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
(1) What is this thing a part of? I haven't a clue.
(2) What is it supposed to be anchored to?
87 951.
TIA
Thaddeus
87 951.
TIA
Thaddeus
Lifetime Member
Lifetime Member
sounds like the test tube for measuring emissions before your converter, if it has broken off and not been welded up you will have an exhaust leak.
Most people just weld them up.
Its suppose to attach near the bottom of the large engine hoist bracket (A-shaped with large 2" hole) at the rear of the motor. You should see a small L shape bracket welded to the metal test pipe near the top where the cap is. On mine the L bracket broke, and its near impossible to re-weld, much less replace.
I took some stainless steel fishing wire and wrap a couple of turns around the test tube and the hoist bracket to secure it, as on my car, the tube would vibrate against my auto trans cooler lines that come up in the same vicinity.
Porsche dealer mechanic was willing to break it off and weld the exhaust hole, as he never used that test tube for emissions checks. He used some other custom tester.
