oil temp sensor/probe
Guys,
Anyone out there with experience on where to connect an oil temp sensor on a 968? Is there a combo sensor pressure/temp available?
THKS
Johannes E.
[ 05-06-2001: Message edited by: Johannes E. ]
THKS
Johannes E.
Not familiar with the oil pan on 968, but this might give you the idea. On my 84 944 we replaced the drain plug with a temp sensor drain plug that was wired to a VDO oil temp gauge that was put in the clock spot. On my 87 944S there are are two drain plugs and we replaced one of them with the same sensor/plug and wired it to the gauge placed below the radio.
