Lean Running 944
When running my stock '84 944 on the dyno with air fuel meter hooked up it runds consistantly lean (14.2-15:1)across the board. I have replaced the temp sensor and fiddled with the throttle position sensor with little change. Where should I look next?
Fuel Pump and Fuel pressure regulator, and the fuel filter, these can all affect your pressure. I had a leak in the high pressure line that was in the wheel well, it was dropping my pressure, that took a long time to track down.
