My 944 Won't Start
#31
I'm back on the trail of the 944 today ..
Thanks for the tip Legoland .. I have one back for you ...
I checked the voltage at the fuel injector connector (with the ignition on) it showed 12v. So, I went to my local Autozone (I had to go twice) who RENTED me a Noid Set.. With the help of my neighbor, he was able to tell me the noid light pulsed. So I bit the bullet & removed the rail ( I stink of gas) This is what I found
#33
Not to worry - I got a whole fuel Rail with injectors & regulators off a 60,000 mile car for $85 on eBay ... I'm another step closer to getting it started .....
#34
If it has pulse at the connector, I am pretty sure the injectors are clogged or stuck. Inadequate fuel pressure will the last thing to check if the injectors do not work.
#35
The injectors can be flow tested and rebuilt at witchhunter.com. I think it is $22 per injector plus a small shipping fee.
I have 2 that I can sell for a good price if you have any problems with the ones that are sent in to witchhunter.
#36
just order up the new plastic tips and O-rings (renbay has them) and clean the injectors with sea-foam, use your finger nail to actuate the injector while flowing the solvent through them, then install the new parts on the injector and reassemble
#37
As you mentioned it - I thought I'd try. Acutaure the injector with my nail ??? No such luck - it's stuck fast .. No way it'll move . But at least now I'me on my way to curing another problem ..new rail & injectors are on the way, along with dampers ... Wish for good fuel pressure for me
#38
For those of you who have been following & contributing, I have great news...
She LIVES !! The 944 started today after fitting the new injectors.. Although my joy was brief, when she stopped again .. However, I did work out that the transfer hose between fuel tank & fuel pump was kinked. This did impede fuel flow. I removed the rubber boot from the throttle body too (to clean a gasoline spill). I ran out of time before leaving for my job, before I could correct these issues. I hoping I can get a fuel hose with an elbow from my local auto store. Then I'll reconnect the boot & hopefully she'll run ..
#39
She Runs !!!!!
A bit lumpy - but the gasoline is the color of apple juice even after several flushes- but she runs !!
Thanks everyone for your help.
The moral if the story here is dont use radiator hose for your fuel needs!! I'm sure the end result was black bits throughout the injectors & dampers ...
Now I just have to reassemble, clean & sell !!
