lost 911 guy needs advice
87 924S listed in local Craigslist; I have not yet seen the car but pictures look OK, but it broke the timing belt. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I texted the guy and he just texted back that the first $400 takes it.
I'm looking for a Chump car build. I'm guessing this car will need an engine rebuild. Approximately how much?
Buy it or run away?
http://augusta.craigslist.org/cto/3919716992.html
Buy it or run away?
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
looking like a partial engine rebuild with a whole bunch of while you're in there to do's.
may as well go all the way to the rod-bearings if you plan on driving it hard.
Proprietoristicly Refined
You asked about the cost of an engine rebuild in 2 posts.
For $400 expect the block piston bores to be ruined.
It cannot be rebuilt cheaply.
Link to an idea on price:
http://forums.pelicanparts.com/porsc...-sleeving.html
Many "good" engines for sale from parts cars.
J_AZ
J_AZ
J_AZ
J_AZ
If any of you water cooled snots would like to save the car, the link is posted above. The owner was a jerk when I tried to talk to him, so it should go smoothly.
Back to the oil cooled world for me.
Team Owner
this..... your next best solution is to source a running engine. a full engine rebuild will be what a shop chooses to charge. the variance is huge, ranging from $7~11 k. the car is basically junk. extremely upside down state of existence. virtually the end of the line. why? because it's not like sourcing a mid-80s 911, doing the restoration and having a car of significant worth when you're done. with this, you have an entry-level Porsche with very little following in the collector/enthusiast world... and not much worth after the running car status is reached. i'm not sure this was the answer you were looking for, but there's a reason this thing is dangling out there for the cost of a decent night out.
Yes, I did, because I didn't get an answer the first time. I'm a 911 guy. I expect to pay $10-14k for an engine rebuild. I'm simply trying to find out quickly, within an order of magnitude, whether this car is worth salvaging, as for $400 I wouldn't expect any reasonably intact car to last long. But thanks for your help.
Gear down man, no one knows the exact cost on a busted timing belt. If its just bent valves its not that bad (you can get a good used head for $400ish usually) if the bores are shot your in the 5k range and at that point your better off finding a running engine on the cheap. I sold the motor out of my 924S for less than $500 not long ago. It needed a cam (didn't know), but it was still way cheaper than a rebuild.
Don't let the rude PO ruin all the "water cooled guys" for you. We are a decent lot (mostly).
PS I'm the guy that keeps DVM's like you alive, I maintain the DVM software for a 3 different Veterinary outfits here in town. They would be in deep doo-doo without this watercooled snot.
