Is it a bad idea to manually shut the heater valve and keep it that way?
The heater on my 87S is stuck on again.
This happened last summer and I fixed it by some miraculous toying with vac lines on the side of the heater core (you see when the glove box is removed)
Anyway, the valve doesn't appear to be getting vacuum. I popped the vac line off that goes to it and felt no pressure/suction.
Until I figure out what went wrong, would it be acceptable to use a zip tie or metal wire to tie the valve closed? Through research I found that this is basically what people do to the early cars with the manual cable set up, but this is a late car with the vacuum set up. I just want to verify that I won't hurt the cooling system, or risk blowing the valve in some way.
I'm no expert on this, so hopefully someone else will reply with a little more experience. But, I can't see where blocking the heater valve would be an issue. It's really no different than if you kept the temp off all the time.
The only caution I'd have is to make sure that you don't leave any vacuum lines open where you could have a vacuum leak.
Today I got
My Custom Title
My Custom Title
My heater valve slider is totally F'd up in my car's cabin and not connected at the valve so, living in AZ and not ever needing heat anyway, I just reached back there in the engine bay and put it to the off position. I don't see anything wrong with doing that.
just saw this topic, i just zip tied my heater valve today to fully closed position, cause when its 87 degrees and 50% humidity getting hot air in the cabin isnt a great feeling, drove around and everything looks ok for now, btw mine is 951 1989 turbo s
I am still worried that it may or may not need to be open during start up for pressure reasons. I appear to have one of the crappy plastic valves at the moment so I'm cautious whenever I mess with it.
I have a feeling that a vacuum leak might be the root of the problem. I intend to dive into that asap. Gotta get this thing to keep from blowing 200º air on me first...hah.
I also see you are from Portland!!! I wonder if I've seen you around before... Not many 968's in these parts...
I don't see anything wrong with it either, but I would guess that the early and late valves are different, so I'm just exercising caution before I contort a fragile plastic valve that has burning hot coolant trying to push through it.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
If anything weird happens be sure to let us know. I'm thinking I'm just about in the clear to commence with operation zip tie.
I have zip-tied the valves closed before with no ill effects, it basically just bypasses the heater core.
You can use a mityvac to test the functionallity of the heater valve, I think orielly's has them to borrow if you don't have one.
If you don't have vacuum in the cabin, check the lines where they pass through the firewall in the engine bay. I find those lines become disconnected all too often, causing the valve to quit working. If they are hooked up, that means you have a vacuum leak which is probably robbing you of a 1/10 hp!
Did you see the 87s parts car in vancouver on cl?
Not sure, live on E. Side up on Mt Tabor. Car is Midnight Blue Metallic which is a very dark blue that almost looks black under some conditions. I was at the PCA arrive and drive in June, and the autox in May.
Thought I'd add one other tidbit about heater valves. My '62 Triumph TR3 that I had many years ago, used a simple water valve on the rear of the engine just like you have for the garden hose. If you wanted heat, you popped the bonnet and opened the valve. Little too basic I suppose for modern day.
Blocking off the feed with zip-tie on the valve works, get it fixed correctly before winter. If you like to breathe and its cold outside you will miss the demister. If you can hold your breath for the entire journey you will be fine
I did not see this parts car on CL. The last thing I need is another dead car in my driveway hahaha.
This is why I've been toying with the idea of the block off plate. I would gladly get rid of the whole system all together and rig up some sort of fan system to de-mist. Thats a project for another time, though.
The more I think about it, the more I like the manual turn on/shut off idea. Lemme at em!!!
Friend of mine has a red 968 cab and he just sold his black 968 coupe. He also has a 86 with a 968 engine. Very nice upgrade.
Are you sure it's the valve that's stuck? There is also a plastic clip under the dash which holds a metal arm, which often breaks. The arm closes the door between the heater core and the blower I believe. So when the clip breaks, the metal arm falls down opening the door, and causing constant heat. Fortunately, it is also one of those things you can just zip-tie back together to hold it. It is located under the drivers side dash toward the center console area (for lack of better descriptions). Won't hurt to check it anyway.
I wonder whose car that was. I have seen it cruising down Division st a few times. I have the neglected blue S2 that you have probably passed many times.
I suppose we should all be able to have the heat up and the fan off with no ill effects. I kind of like the cool breeze that the leaky flaps and joints let through when there is no flaming hot coolant running through the core. Thats why I want to cut off the line.
Just ordered up a manual control valve to try and throw in there so we'll see what happens.
And just because I like creating problems for people,
http://portland.craigslist.org/mlt/cto/3896619031.html
900 bucks... You know you want it for parts...
