Anyone ever put Cascade in the cooling system?
Yeah, I cleaned the cooling system on an old 5L ford engine, had about 200,000 miles on it at the time, seemed to work well, but I don't know if i would do this to my 944. If you do, make sure to flush all the soap out before finishing the job. Oh, the ford van now has 298,000 miles on it; just can't make the big 300.
My grandfather used to tell me stories about how they kept their cars running in the 30's. Besides the old molasses and feathers in the tires to stop slow leaks, he used to use kerosene as a coolant in the radiator... said it wouldn't freeze and worked fine. I asked him if it ever caused engine fires... he said naw, just smoked a lot if there was a leak..
Now there's something I would NEVER do... but I don't heat houses with coal or tip outhouses over for fun either...
Thaddeus
Thaddeus
LOL! He has got to be pulling your leg Thaddeus re: kerosene as a coolant. Kero has a flash point of about 130 F, so you would have to be nutz to want that in your radiator where it could boil out onto a hot engine.
Likewise with the home leak fix. All those tires used tubes back in the old days so would be sort of tough stuffing feathers through the valve stem. As I recall tubeless was patented around the turn of the century but didn't come into use until the 50's.
While you guys are cookin with H2O, here's another old wifes tale. Someone told me to drop an egg (sans shell) in a leaking radiator. Supposedly it will plug the leak. BTW it also is supposed to smell terrible.
All we need is a place for the bacon, and we're off and drivin again.
I've done it it works for gasket sealing egg whites and black pepper, needed to do often but did work
For a sparkling clean cooling system with hardly any spots...
I was told that if you had the oil/coolant doing the tango in your oil cooler, then you should clean the cooling system once the problem is fixed. And that Cascade dishwasher soap is a good thing to use for this.
Basically you fill the cooling system with water then add a couple scoops of Cascade, start the car, get it up to temperature, run it at ~2K rpm for a bit (the service manuals describe this more precisely).
Has anyone ever done this, and if so did you flush the cooling system with plain water afterwards before adding coolant? Did it work?
Thanks,
Bryan
Thanks,
Bryan
Mercedes has a write up on using citric acid powder in the 450SL cooling system. You block off the thermostat bypass so the water flows through the radiator all the time then drive it 30 minutes. You flush out the running engine untill clear, drain the water then put in your coolant. Some of the owners have used Cascade also and report good results.
For the very brave, drain your system put in a gallon of meratic acid and drive it thirty minutes with the thermostat removed, then flush it out while the engine is still running. I did it to a 73 TR6 with a really rusty engine that was all clogged up. It really did a good job, but if the radiator is really in bad shape that could be the final event for it. But the passage ways were open when we put on the new water pump while doing this!
Thinking about this I had visions of mixing CLR and de-greaser...but seriously, wouldn't a commercial rad flush be the best choice?
The HD mechanics where I worked used Cascade dishwasher powder to clean out the radiators in the 40T forklifts. Those rads were worth many thousands and they swore it was the best way although it was premixed before adding. I have done it a couple of times when I got a vehicle with the coolant in a horrible state. Run it a few minutes then flush it out. I would be leery of pouring crystal into the system and hoping it would all dissolve.
