Light problem - '83 944
Ok, I checked all the fuses they are fine. However, suddenly my sidemarker lights (front and back), interior insrument lights, and rear lights (all of them)are not turning on. Only the headlights are working as they should, along with emergency flashers and blinkers. What should I look for? Is there a relay or something? Thanks in advance
Athens944
Weird combination not working...
May want to start checking the ground of the rear lights in the trunk (under the left light in the body, 10mm hex bolt with a lot of brown wires)
The instrument cluster can be a realy or maybe the grounding under the dash
You can find the wiring diagrams here:
http://www.pelicanparts.com/944/elec...l_diagrams.htm
Good luck
Good luck
