Upper Strut Bearing
Upper Strut Bearing
Is there a way to check its condition without dissasembling the strut? I want to make sure I get this right before I spring the big bucks to get the alignment set. I suppose I could dissasemble the strut and inspect but I feel like a dummy cause I just paid someone to install new coils on them and put all the old stuff back in (strut inserts have only 3k miles). Well, the only "special tool" I would need is a spring compressor right? How do I keep the strut from turning when I reinstall the lock nut on top? there is a flat spot on the threads but it looks too small to put a fatty wrench in there. When will I get this right? Will I ever get a wheel alignment? Why is the sky blue?
Indicative only: lift the car so the pressure is off fron the bearing and try to feel for the play while pushing the strut around.
..."special tool" I would need is a spring compressor right?
Saw a guy loosing some fingers once because he was stubborn enough to try with one of the "cheap & nasty" things.
