931 engine pre-install refresh items?
OK, FINALLY going to put the engine in the 931. Before I dump it in there, while it is on the stand, what should I refresh while I have easier access? I am assuming the rod bearings... What about any seals, etc? I am more familiar with the 944 engine, and unsure as to what general refresh items the 931 will need (this is a used engine) and what access issues I will run into when the motor is installed.
Any advice/info would be appreciated!
