Rear Wiper problems
Rear Wiper problems
The problem has been there since I bought the car (2 months ago). Whenever I try to use the rear wiper it eventually ends up falling off the drivers side of the car. It will work for a few strokes (seems pretty noisy though..IMO) and then at the begining of the stroke (vertical positions) it will sit there with the motor spinning. It then thinks its in the horizontal position, so it moves to the vertical position, which puts it off of the windshield.
I think that the gears are semi-stripped. Or the wiper is lose in its attachment to the wiper drive system. How would I go about taking it all apart? Anything to know before I go in there?
thanks in advance
thanks in advance
Did you try flipping up the cover over the blade/motor attachment and watching what's happening? If so, it will be obvious if it's stripped at this point. Mine was exhibiting similar behavior, and the gear there is probably about half stripped, but I was able to cinch things down and get it to work.
For precautionary statements should further disassembly be necessary, see the thread I've got going about the motor assy "belching oil." Thanks again to those who replied there.
T
T
OK this post gave me the spirit to go check it out. I took the plastic and metal covers off, then ran the wiper. And whadayaknow....it worked fine! Put it all back together...still worked fine! We shall see when it rains. Everything looked fine in there...all gears in tact..plenty of lube.
Thanks!
Thanks!
