HELP with the flex plate dampener on a auto 944
Old 05-20-2013, 05:55 PM
Alomeli44
Alomeli44's Avatar
Default HELP with the flex plate dampener on a auto 944
well my flexplate dampener is gone and im in the process of replacing it. so far i will go through what i have done.
-transmission completely dropped.
-all bellhousing bolts removed
-9 flexplate bolts removed
-reference sensors removed
-starter and all the other good stuff removed
-seems like the bell housing is getting caught up somewhere from the top not sure where!!! please help need to get the bellhousing separated to pull the torque tube to remove circlip!!!!!
Old 05-20-2013, 07:45 PM
John_AZ
Proprietoristicly Refined
John_AZ's Avatar
I have no idea but to give you this link:
https://rennlist.com/forums/924-931-...er-clutch.html
GL
J_AZ
Old 05-21-2013, 02:48 AM
FRporscheman
FRporscheman's Avatar
Did you unbolt the ground cables?
Old 05-21-2013, 10:15 AM
dp951
dp951's Avatar
Default Bell housing 944 stuck
Did you remove the ref sensor bracket or just the sensors , the bracket has a tube that sticks out, you have the 10mm ground as well as the larger 13mm that also holds a ground
you can ring me 305 542 1612 Dp
Old 05-21-2013, 12:42 PM
GGX2
GGX2's Avatar
My 83 bellhousing wouldn't move back because I didn't realize there were two clamps holding the starter cables to the bellhousing, did you get both of them? There's one on the top of the bellhousing that is really hard to get off.
Good luck with it.
-George
Old 05-21-2013, 01:36 PM
Vincent C.
Vincent C.'s Avatar
the trans cooling lines are bolted to the bellhousing....and like DP said, make sure you have the sleeve out for the crank sensors.....vinnie
Quick Reply: HELP with the flex plate dampener on a auto 944
