Automatic Damper/Clutch
Can someone give some knowledge if they have done the conversion to Manuel clutch in a automatic,(What exact parts will I need)Also the bell housing is giving me a hell of a time getting off,Do you need to take of the clamping piece(#22)to slide it back,I know there is a circip(#25)also the cooler lines on top and another hose on top seem to be in the way of the bell housing.How does your car run with the Manuel clutch in.Thanks
Ok I found this write up,but not sure were this 8mm allen is,
Ok, that pain in the @$$ circlip was easy. All that is needed to be done is loosen the 8mm allen bolt that clamps the inner damper to the tt shaft and it slides back about 1 1/2 inches, making it easy to remove the clip upon sliding the washer back with the damper. This made my night better all it took was a beer in hand and some thought!
