What is this part? Arg.
Had some richness problems and located a vacuum line that was flopping around in the breeze. Seems that the check valve had rotted to pieces and needs replaced.
Found the check valve (433-862-117-M93, an Audi part that is identical to 928-537-361-02, I guess?), but can't find the part number of the four way connector that connects the check valve and the banjo fitting on the manifold that (picture attached). Any help?
![](http://img51.imageshack.us/img51/8352/whatisthisk.jpg)
