Proper Amp placement and speaker hook-up in a 944?
I have the following set-up - JVC 35w head unit, Panasonic 4x6s front, infinity 4x6s in rear seat, infinity 6x9s in hatch. I just purchased a 200 watt (75 watt per channel), 2 channel, jensen amp.
I want to put the amp in the well under the hatch carpet - is this a proper location or will the lack of air circulation cause the amp to overheart?
Also, I only want to power the 6x9s with the amp. By connecting RCA cables from the head to the amp, will I be cutting out any sound to my 4x6s?
Thanks -
Jeremy
1983 Guards Red
Thanks -
Jeremy
1983 Guards Red
Which well? Side cubbys or spare tire? There shouldn't be a heat problem really in either. I have 2 Kenwood amps in my spare tire well and have never had them shut down. Just be careful you don't put a screw through the sheet metal and into the gas tank!
Originally posted by Jeremy:
<STRONG>Also, I only want to power the 6x9s with the amp. By connecting RCA cables from the head to the amp, will I be cutting out any sound to my 4x6s?
</STRONG>
</STRONG>
are you running all 3 pairs of speakers off your HU?
Thank you for your assistance. Yes, all 3 pairs are currently run off the head unit. I am hoping to disconnect the 6x9 speakers and connect them to the amp which will be wired to the HU using RCA cables.
Jeremy:
I'm considering doing a speaker install like yours. Currently, I have 4x6's up front and 6x9's in the hatch. The previous owner had the 4x6's in the back seat area disconnected.
Can you tell me how you wired your speakers and how you spliced them? Also, I'm thinking of adding tweeters up front to raise the sound to ear level - how do you recommend I connect the tweeters? (everything sounds really low right now with the fronts' placement)
thanks!
sm
thanks!
sm
SM -
To be honest I am not sure how they are wired as it was already done when I purchased the car. The PO had panasonic 4x6s in the front, OEMs in the rear seat, and Pioneer self contained speakers in the hatch. I changed the rear seat speakers to Infinity kappas, and the hatch to 6x9 Kappas in boxes. I have a 1983 and although it was tricky, I did not need to remove the windows to replace the speakers. I am hoping to install my amp this weekend so if I am able to figure out how it was wire, I will repost. Sorry that I couldn't be more help -
Jeremy
Jeremy
Originally posted by sm:
<STRONG>Jeremy:
thanks!
sm</STRONG>
<STRONG>Jeremy:
thanks!
sm</STRONG>
Thought I'd let you know what I did for two installs.
I installed the amp under the glove compartment, Depending on how thick the amp is, should leave plenty of room for pass. Then I installed new 4x6's (eclipse) in the door panels(had to enlarge hole and shimmed out the oem grill's slightly) and in the rear pass area. Then I cut out for 6x9's (eclipse) in the hatch area (right and left sides), removed the padding under the carpet(sides only) and made plywood mounting panels for the speakers to go under the carpet. It makes for a real clean install and keeps the rear speakers to the sides so you can still haul those extra Porsche add on's. You can e-mail me if you want more details. eworkley@earthlink.net
