924 Engine Parts FS - Mostly Race 924/931/933
I used to support a couple of 933 race cars for PCA (great cars, BTW) and now have parts taking up too much room on the shelves. Nothing is junk, or I wouldn't have kept it. You can pay via PayPal, and I'll try to ship via cheap USPS boxes. Probably best to PM me with your needs. I've tried to price very reasonably.
924 PARTS
931 pan with turbo oil drain attached 100.
931 pan 75.
933 dry sump pan with 2 scavenge sections 150.
931 bell housing with TOB arm 150.
933 dry sump pan with short sump and single scavenge - factory prototype? 150.
931 pan - NEW wet sump with custom baffle insert - factory prototype? 125.
933 pan - dual scavenge 150.
7 2.2L custom JE pistons (2 new) 150.
931 head gasket NEW 25.
924/931 head studs - custom race 100.
931 valve cover
20 931 head bolts and washers 50/set
4 block dowels for cylinder head - NEW
8 used solid followers / race 100.
Cam spray bar - NEW 7.
2 pilot bearing seals - NEW 5/ea.
8 race valve springs - NEW 100.
1 pilot bearing - NEW 10.
10 head bolt washers - NEW 10.
Snail gearbox parts - what do you need?
2 solid race cams for 933 125/ea
1 clutch assembly 650. Alum flywheelSingle disk 7.25 Quartermaster clutchDisk for small shaft
1 clutch assy 800.Alum flywheelTilton dual disk 7.25 clutch2 disks for small shaft2 disks for large shaft
1 clutch assy 700.Alum flywheelSingle disk Quartermaster 7.25 incl. TOBLarge shaft
1 NEW alum flywheel and NEW 7.25 dual disk Tilton clutch 850.
933/931 race valve springs 120./set
931 std. valves 10.ea.
JRZ shocks for 924 / early 944 - double adjustable - NEW 3500.
4 BBS wheel fans for 16" B.O.
924 snail shift rods / linkage - stock 30.
4 Cunningham billet rods 400.
4 JE coated pistons 2L / 933 150.
13 solid lifters / race - new 20./ea.
2 fabricated crank sensor brackets for crank snout 20.ea.
48mm Weber soft mounts and gaskets 10. ea.
Misc 931 engine parts: water pumps, brackets, lifters, pulleys, water consoles, etc. from core engines
931 bare head - NEW 700.
931 core head - complete 200.
931 race head ported with helicoil in #2 spark plug 300.
931 stock head - LOW TIME with cam, pulley, cover 500.
931 race head with one mildly damaged chamber - repairable 175.
924 PARTS
931 pan 75.
931 valve cover
Last edited by michaelmount123; 04-17-2013 at 12:44 PM. Reason: List didn't show indents...
