A/C Noise
A/C Noise
What's that screeching noise when the Air condition switch is on after I start the igntion? The sound disappears as soon as the car starts. Would it be the condensor motor goining bad. Does it need lubrication? I have my original A/C on 924S 87. I had to recharge the freon last summer for the first time. Any help would be appreciated.
PAR 924S 87
PAR 924S 87
Loose belt, to check if that is the problem,, carefully take a bar of soap. Place it against it while running.. If that is to dangerous for you they make a spray on dressing.. either way after you apply it see if the sound is still there.. if it is then it is not the belt.. If it goes away I recommend replacement of the belt soon..
