URGENT: PS Rack question...
Look here, or at the attached image:
http://freehosting1.at.webjump.com/1...bjump/rack.jpg
Does the power steering hose come apart at this joint?
I turned the "round side" of this round/hex joint thinking that this is the place that you disconnect it...
This joint does not seem to be threaded together, even though there is a hex on one side, hopefully I did not damage the connection by turning it 180 degrees.
Thoughts?
Thoughts?
I agree with Skip.
Unfortunately, this is a crimp on the hose to the hard line, even though the fitting looks like it would come apart. I think the line is toast and wouldn't use it (high pressure side of PS). Sorry.
