How to remove badge panel??
How do you remove the badge panel (to get at the IC) I assummed it was the same as an S2, but isnt. Do you need to remove the front bumper or am I missing some hidden screws? (removed all obvious ones and it wouldnt come off)
thanks...
si 91 951s
thanks...
si 91 951s
Check out Lindsey racing's web site.There is a pictured story of the whole procedure. http://www.lindseyracing.com/swap.htm
Olli
'88 951
Olli
'88 951
4 screws on top in engine bay, 2 screws under each light holding it to the bumper, one bolt under each light that hold to the fender (often missed), and 1 screw under each light towards the center of the car by the intercooler, these are up high near the top.
good luck
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
good luck
