Water pump ?
Proprietoristicly Refined
I only know of the brake MC having a "weep" hole
![Name: master cylinder weep hole circled.jpg
Size: 35.0 KB](https://rennlist.com/forums/attachments/924-931-944-951-968-forum/718789d1365466757-water-pump-master-cylinder-weep-hole-circled.jpg)
I have pressure tested my WP and the only "weeping" came from the gasket to block.
J_AZ
J_AZ
I had a small steam cloud rising from under the turbo block off nipple on my 87 na. Stuck my hand under it and got some residue that smelled like coolant. TRying to figure out where my little escaping vapors are coming from.
There is an "O" ring under the "block off"
http://www.pelicanparts.com/cgi-bin/...FILTER_TOOL=ON
If you pull the front belt covers and grab the WP pulley, any unusual movement means the WP bearing and seal are bad------must replace now----Zims has the best WP part and price.
J_AZ
J_AZ
