fan blowing on low when car is in acc/started normal?
So I noticed if I turn the car to acc or I start it the fan is blowing on low speed, and I haven't figured out how to turn it off. The fan speed is at 1, the a/c button is not pressed, and the circulate button is pressed when this happens. Is this normal or am I missing something here?
does it run all the time until the car gets to a certain temp, then run on full speed?
If yes, it's likely your coolant temp sensor (for the fans) has failed. You can test it as per the workshop manual in a water bath on the stove
If you are talking about the blower fan in the car, it is always on and can't be completely turned off. Designed to keep a flow of fresh air I imagine.
Fara, thanks for trying to help.
Veleno,
I can confirm what Eric says...once the car is started, the cabin fan turns on at a very low speed no matter what the switch settings. This is normal operation.
