Anyone near Sacramento with an 89 n/a
My car won't start and I've tried everything except plugging in another DME,
I will pay for your time and fuel just name your price all I need is to borrow your DME for 1 minute!
thanks, Scott
85 944 driver
87 944S engine almost in
89 944 no spark no fuel
thanks, Scott
85 944 driver
I read about it on Clarks Garage and it said something about the injectors wont fire due to the higher voltage and it could mess up the dme! However after comparing the two schematics the only difference is the early dne shows a couple volts higher at the afm pin so I don't know I think i'm just going to plug it in and see what happens! The clutch blew up today in the 85 so what do I have to lose besides another day of work! I have no transportation now I went through 2 porsches in 5 days It can't get much worse can it?
Small Business Partner
The DME/AFM change-over is the same as the interrior change-over. 85 and older have the early DME. 85.5 and newer have the late DME.
You can safely plug in any 85.5 and newer DME into your car for testing. Do not plug in an early DME without also changing the AFM.
