Time estimate for a head gasket?
Never did one on a 944. Am fairly handy with a wrench and have changed my own WP belts rollers etc before myself. So ball park how long of a job is it? Been doing my research and I am thinking one long day should get it done.
This comes from the fact that the exhaust stub is broke off in the block, and nothing is working. It is the very bottom bit of the stud, it's in there deep.
Considering pulling the head and putting on the spare from a 85.5 parts car. Will have it inspected before hand. Would use the chance to put on powder coated intake and exhaust manifolds, nice painted cam tower and of course replace all the gaskets. Advice welcome.
And last but not least Happy Easter everyone.
Michael
Michael
Proprietoristicly Refined
A day would be enough with your past experience.
The process is lengthened by WYAIT (while you are in there) jobs if not up to date.
AOS seals
Clean the ICV
Test the lifters & replace "soft"
Exhaust stub work while engine installed and difficulty to repair--the "nothing is working" situation.
Tension and retension of belts once complete.
Seal leaks in the lower balance shaft housing. (Rear "O" ring)
More? Yup, just the beginning.
Removing "carefully" all old gasket material can consume more than a couple of hours. I use Acetone, soft blades, Scotch pads --still takes hours.
Do not remove the top carbon seal ring on the cylinder walls. Helps seal.
If you must clean the tops of the pistons, seal the piston top to cylinder wall with grease ---then remove-lower the piston and wipe away --to prevent chips of carbon getting between the cyl wall and piston skirt.
One weekend or 2 full days if all goes well.
I list removed items as I take them off or disconnect. I spent a couple of hours when the connection to the AFM was not on tight.
Thanks for the Easter greeting and good luck. Enjoy the day.
J_AZ
AOS seals
Clean the ICV
J_AZ
I'd say roughly 6 hours. Remove the head with the exhaust manifold attached. Make sure you have the triple square driver for the camshaft bolt. And a long 6mm allen wrench socket for the cam box bolts.
May want to put in a fresh water pump and belts while you're in there. Also might want to change the oil pump drive gear, front main seal and balance shaft seals while you're in there.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i was losing a gallon of coolant about every 5 miles out the tail pipe.
a friend suggested headgasket sealer [once the coolant was out]....
i first used a 60 dollar bottle of Bars Leaks headgasket sealer... added to 100 percent H2O as per instructions.....
about 18k miles later i was losing a bit of coolant [turned out to be via the H2O pump which had 60 k miles, and it's now well established that Porsche's replacement pumps are junk.... proven again] and added Blue Devil just to be safe....
changed out the belts and H2O pump [now 600 miles ago] and put in distilled water.... added more Blue Devil with the cap off.... and about 2 hours later after evaporating some of the water, i added about 3/4 gallon of antifreeze [concentrate].
i changed to Blue Devil because all the mechanics i talked with, said it was a superior product to maintain a successfully treated head gasket. had one mechanic tell me that a solid like Bars Leaks plus Blue Devil was an unbeatable combo, [solid, then later to add the liquid] because the Blue Devil forms an epoxy layer [like clearcoat] over the solid.
but who can be sure. but i've got a car that's running good [for a year] without pulling the head or getting hot.
as far as Tony Starks, "oh man, i just ride em... i don't know what makes 'em work."
as a mechanic, i'm in the purely anecdotal category as everyone knows [illustrated in the following clip].![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Team Owner
yes.
the buyer (a neighbor of yours) is 100% aware of the headgasket failure.
i'm much more concerned that he may have to re-coat the cylinders.
but he's also prepared to take on that challenge....
Michael
Michael
AOS seals
Clean the ICV
J_AZ
AOS seals
Clean the ICV
J_AZ
You are one of the most respected RL members and I have watched & bookmarked all your videos and many posts.
Your garage and tools make my garage pathetic.
6 hours?
You have previously posted the "shop hours" is about 10? and add more if a problem.
F4OLM has a broken stud.
Porsche Doc says 11 hours..
https://rennlist.com/forums/924-931-...n-an-83-a.html
Just to torque the head takes an hour or more. Clarks lists "wait" time between steps at 15 minutes. I wait at least 30 minutes between steps.
Just a courteous disagreement on your 6 hour time.
I tend to be more realistic.
J_AZ
Team Owner
Van ?
why yes; our dear friend could do it. i betcha he could.
having been inside the sacred walls of the Temple,
i know he is no mere mortal.
About 7 hours seems right I did mine about a month ago. That is if all your gaskets come off cleanly.
I spent another 5-6 hours scraping off the old cam tower gasket while using High VOC Gasket remover that burns hands.
