heater control valve for 16V engine
Porsche moved the valve to the front on the S and S2, which keeps it from leaking onto the clutch. The only negative is that it makes getting to the oil filter a little harder.
Kevin
Catellus Engineering
Kevin
The all metal HCV for the Audi I know of is made by 4 Seasons with part #74671. However, based on my experience, you can get either the all metal part or the half-plastic-half-metal part. Both parts have the same part number and getting one or the other depends on which online supplier you are getting it from. Both are better than the all plastic OEM part IMO.
Btw, my friend fabricated a relocation kit for the HCV for the early, late and all 16V 944s models. He has it installed on his '85 944 with 968 motor and will be installed on my 3.0L 16V conversion too.
Dimi, to where does your friend relocate the HCV?
Spencer, here is the valve:
http://www.napaonline.com/Catalog/Ca...410_0403483100
Like Dimi said, sometimes they give you a half-plastic one, so return it and buy another one until you get the metal one. I've seen both silver and yellow zinc.
