SFR TURBOS
SFR TURBOS
can I install a SFR stage 3 turbo on a 2.5 with WF gasket, AA stage 2 chips, LRBE, LR wastgate, injectors,fuel pressure reg, and boost controler? Do I need any other mods to run this turbo? How much boost can I run and what HP can I expect from that psi? Do I have to have a MAF? Any info would be great.
You really should contact them directly. John's e-mail address is blackbox@san.rr.com He's very helpful and would be able to provide much more info than the board is able to give. HTH.
Minh
Minh
Our level three will bolt right to your 951 stock block :-)
The chioce of the WFR gasket is definately a plus.
If your not running a MAF kit then we can provide you with our K26 bolt up kit.
From this point, any upgrades you make to your 951 will fully compliment the turbo you have installed.
Thanks Minh, your very kind, please call me to talk about the wastegate kit...I think I can cut you a deal :-)
