Which relay controls the passenger side fan?
![Red face](https://rennlist.com/forums/images/icons/icon11.gif)
My passenger side fan is not working, however, the driver's side fan does (turns on with AC on, or when engine is hot and AC is off). The motor is fine in the passenger fan, so I am trying to figure out which relay controls the passenger side fan? Thanks -
Jeremy
Jeremy
Hey, did you check fuses? Check a wiring diagram it will give the location of every component. Where it is physically in the car, how many pins are in each connector the wires go through, where the connection is to the junction box and what position the relay sits in the panel. The grounds are also numbered and there should be a list where the ground for that circuit is located. Find another component using the same ground, verify its operation and you have a good idea that it MAY NOT be ground fault. Then again you may have checked all this allready. Note: the fan switch very commonly goes bad. A lower temp aftermarket replacement (for VW) may do the trick (10-12$).
Good luck. Sometimes electrical problems can be a nightmare.
