installing momo wheel on an airbag S2
installing momo wheel on an airbag S2 UPDATE! STILL NOT WORKING
i have been reading countless posts about horn issues and air bag lights and here is what learned
1- install a 3ohm resistor to avoid the airbag light (ok)
2- to get the horn to work... its a different story with all different wires ....
this is a picture of my hub and the momo horn button, can anyone tell me where each wire should go?
thanks again
thanks again
There is a stock part which fits into the turn signal assembly. Push and play. Not sure what the part number is off hand, I think it's a 993 piece. No special wiring required, you just push in the extra part.
heed help
i picked up a stalk from a 90 928, as seen in the picture.
i noticed there a ground cable from the old connection with no where to go? any ideas?
so far, the hub ring makes contact, i connected the black ground from the hub to the ground on the horn button, and other wire (green) goes from the horn metal rings to the other plug on the horn button. NOTHING!
i appreciate any help
