Upcoming master/slave cylinder replacement
You may be right about getting the shaft lined up for installation... I've recently removed 3 from various parts cars - but it's been a while since I put a new one in. You can certainly remove it without going under the dash.
I saw a thread where someone accessed the shaft clip by lifting the fuse panel from it's tray. I did that once to get to a positive wire and it is a creepy feeling pulling up on that panel with all of those wires packed down underneath the fuses/relays. Also, there is a guy on youtube who shows the whole process but he speaks in Dutch? He does have English captions though if you click on the closed caption symbol.
