FS - Porsche 944 rear lock seal grommet
Old 03-07-2014, 11:39 PM
athens944
athens944's Avatar
Yes, you are correct! It fits nicely around the lock cylinder.
Keep in mind, some of the older sun-baked grommets simply crumble.
Old 03-07-2014, 11:40 PM
odonnell
odonnell's Avatar
I replaced mine a few months ago, and it helped to loosen some of the screws from inside the trunk. IIRC there were a couple that just have it a little more play. Once you look at it, you'll immediately figure it out.
Old 03-07-2014, 11:45 PM
mel_t_vin
mel_t_vin's Avatar
Originally Posted by Bill 944 S2
It may seem obvious, but does the old one just pull out and the new one push in from the outside?
Yes, but, depending on how old your grommet is, it probably won't come out in one piece.
Little, if any, lube is required to get the new grommet back in. It's a snug, not tight, fit.
Old 03-08-2014, 05:33 AM
Voith
Voith's Avatar
How much for shipping one to me?
Old 03-08-2014, 06:26 AM
athens944
athens944's Avatar
PM your shipping address and I will give you a quote.
Quick Reply: FS - Porsche 944 rear lock seal grommet
