Shims under valve springs??
I took apart the head on the ChumpCar motor... and I was surprised to find little shim washers under the valve springs. Or, more specifically, I was surprised to find *inconsistencies* with those shims - 3 of the intake valves had two shims while the last valve had 1 shim... And 3 of the exhaust valves had 1 shim, except one, which had 2 shims.
I just looked in PET, and I see that the shims are #14 and come in 2 different sizes... When I found 2 of them, there is a fat and a thin one. Were these used to compensate for variations in spring force?
i have seen shims in 924 buckets befor to get the right amount lift when using a race cam, as for the corrosion its normal for a motor that is 20 years old, and depends on the coolant or water used in the engine, and you do get condensation from short hops and not geting the oil hot, ( probibly befor it was a race car)
The only thing these shims would do is put more preload on the valve springs - and it seems to me that 0.5mm of extra pre-load isn't much at all...
The different shims are to take up variance of valve depth to retain the proper spring pressure.
It sounds excessive to have 3 shims.
I personally have added a .060 shim to bump spring pressure. However, I measured to make sure there was no coil bind.
sid is correct the valve springs have a installed height spec, all valvesprings do. you use a special micrometer to measure distance from spring pocket to the bottom of the retainer. you then add shims to get the correct distance.
Ahh, gotcha. I understand now.
Here's another question: is the little tang of metal in the oil pump supposed to look like that? Or is this one broken? I've done a google image search, but I can't find that specific view.
