Best place to buy Clutch Kit/flywheel?
Got a 89 n/a 2.7l and need new clutch and would like to change flywheel also just to be safe.
Where would you guys recommend me to buy it from?
Former Vendor
For more information on clutch kits Click Here
Would also like to know for future reference.
cheapest place I found was ebay, but it wasn't a significant margin. Main reason is because the vendor offered free shipping and was about 15~20 bucks cheaper the higher "stage" of clutch you got. Stage one, 10 bucks cheaper, stage two, 25 cheaper, stage three, 45 cheaper, ect.
I got a spec stage two for a stock 85.5 N/A. I've heard some bad things about spec but some good things too. I wanted something slightly beefier than stock, but driveabilty close to stock (not an on-off switch) so a stock sachs was ruled out.
Rainman
http://www.ebay.com/itm/SPEC-Aluminu...-/310321830663
http://www.horsepowerfreaks.com/part...5//Porsche/944
http://www.ebay.com/itm/Fidanza-flyw...-/310087279523
http://www.automotion.com/fidanza-li...r-porsche.html
at the price the OEM flywheel is going for it would be at least worth considering an alternative...lighter flywheel does mean a bit trickier to start from a dead stop though.
clutch disk you can get re-lined at a local clutch shop...i got mine done for ~$80
Late Porkchops
Every call to Paragon has been a good one for me - although I did not buy a clutch. If I did need one, Paragon would be the first call.
http://www.paragon-products.com/
