Instrument cluster refurbishment
As a buddy who is an aeronautical engineer likes to tell me - AE's build weapons, CE's build targets!
The Good: I got the instrument cluster back in the car and all works well. The LED lighting is not as bright as I had hoped, but it's certainly an improvment. I'll take a picture and post it shortly.
The Bad: I think I out-smarted myself. (Which isn't very tough, really.) After I got the cluster plugged back in, and before I replacd the trim, steering wheel, etc., I re-connected the battery and started the car to check the functioning of the cluster. Apparently, this was a bad idea as now the airbag (and seat belt) lights are illuminated and won't go out. Note: Due to time constraints, the car sat for two days with the battery disconnected before I finished re-installing the steering wheel and airbag so there was plenty of time passed between checking the cluster and final installation.
I'm guessing I now have to figure out how to reset the codes. Oh well...
I think Clark's garage has a process for 944s to reset the Airbag light. not sure on Seatbelt light.
Are the bulbs plug and play? I have to take our my cluster and wouldn't mind putting in LEDs in the reflective housings (3 I think) - did you do all of the lights in your cluster with LEDs?
The bulbs I bought are plug and play, and I noted the part number in an earlier thread. I only replaced the three bulbs in the reflective housings with LED's. I have no problem with the other lights.
That said, the LED's are not as bright as I had hoped. The look is good, just not bright enough so I may do some more research (I thought I'd gotten it right!) to find brighter bulbs.
I may end up trying to put together a test rig from Clark's for the airbag light. I'm not great, electrically, but it looks pretty simple.
944, cluster, gauge, greensboro, instrument, instument, kc, nc, powered, rebuuilder, refurb, repair, speedometer, vbulletin, vdo
