Where is my oil warning light?
I have the cluster out right now, PO clean up it feels like. Anyways found out there's no bulb in the check engine socket (big suprise). Also cant seem to find where the oil dummy light physically should be in the cluster. According to the FSM it's in the tach?
I'm experiencing an intermittent oil pressure issue according to the analog gauge. I wouldn't mind some reassurance that I can at least fire it up. (Granted yes manual gauge would tell in short order)
I know I need a formal intro sometime, I lurk. Car is a 1987 NA. I'll have pictures up sometime.
Low oil pressure is just at the bottom of the analog oil pressure gauge. Low oil level is, I believe, just the exclamation point in the tach (I think only '88+ cars have the oil level sensor).
That's how mine is. I had a low oil warning a week or two ago and it's just the exclamation point in the tach (87 Turbo though).
Last edited by ehokana; 10-21-2012 at 11:10 PM. Reason: Sometimes the convenience of an iphone is outweighed by the stupidity of the button placement
