Rubber bumper guard bolts rusted out... ideas on another way to attach them?
All 4 of the rubber bumper guards on my 924S are coming away from the bumper because of the metal plate molded into the rubber is rusting away. There has got to be a way to reattach them since the rubber is still in good shape. The easiest way would be to drill holes through the rubber to line up with the mounting holes in the bumper. Painted black they would be almost invisible. Only problem is that they might damage anything that ran into them. Maybe recess them a quarter of an inch, if I could drill a clean hole in the rubber... not sure about that.
Any ideas appreciated.
Hey Man
Trust me it's much, much easier to find someone selling a set in good condition. I went through this twice with 944's and there's really not a good way to repair them. I don't think I ever paid more than $10/each; compare that to the time and frustration trying to repair one. Good luck with whatever you decide
Hates Family Guy
Depending on how rusted the metal plate is, you may be able to drill another hole in it near where the stud was. I did that and ran a 1/4" wood screw with a hex head into the rubber. I'm not sure if it held more into the metal or the rubber, but it was solid.
Since I have no budget left 8 wood screws sounds better than even 40$ for replacements. If it doesn't work... hopefully there will be something in the budget sometime in the future...
Thanks.
... and they do hold in rubber. The fourth mount point where there is still metal is attached with a 1/4 in screw as suggested by Kurt R.
I'll see how this works out over time... but it is solid enough to get though my upcoming inspection.
I tried repairing mine and didn't like the fit. The rusted metal had expanded and caused them to not sit flush. After an evening or two of wasted time I shopped for like new replacements.
Ya, once the metal starts to rust you have to get it out... which is not too hard.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i'm thinking you can clean alll the rust away and replace withepocy resin.
i know of 2 products that are extremely strong.
1. Solarez epoxy.
http://www.solarez.com/productsnew/UVepoxy.html
http://www.solarez.com/productsnew/epopint.html
2. Devcon plastic welder.
http://www.all-spec.com/products/143...FcxcMgoddnMAFg
spread a this stuff over a large enough area for supporting a long nut.
http://www.alibaba.com/showroom/long-hex-nut.html
1. Solarez epoxy.
