very nooby question..
Does anyone have a link or a picture of a 944 engine bay and transmission bay with diagrams and labels? I just got my car a little over a week ago and I have little to no idea what fluids are supposed to go where. Also, does the radiator fluid the big box in the bottom right corner?
You only have the trans-axle fluid. In the rear, fill and drain plug 17mm I believe. Cooling you need to drain the radiator, bottom driver side. Its a blue plastic bleed screw normally, careful with it. and you have a drain on the side of the block, passenger side under manifold
Looking for something like this? I'm not sure if your car is an early or late style 944. Mine is a later one, but the engine bay should be roughly the same on the early versions.
![](http://i135.photobucket.com/albums/q150/jmtrotz/100_08219t4434fds9.jpg)
Transmission labels (sorry, I don't have a full picture of the transmission to label everything. I'll try to get one)
![](http://i135.photobucket.com/albums/q150/jmtrotz/2007-trans-driver-side.jpg)
Last edited by Chunkerz; 10-09-2012 at 02:21 AM. Reason: better/more detailed picture
WRONGLY ACCUSED!
Received 4,102 Likes
None of these photos show the turboencabulator. How is he supposed to work on his car without that?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
