My experiences with a ford MAF
I read a few things about the ford contour maf so I decided to give it a try. Results were better than I expected honestly. With a little tweaking(thanks to rouge's xdf) I believe I can make this work pretty well.
The video says most of it:
I hope I don't anger any of the vendors on here as I do appreciate all of the aftermarket support there is for these old cars, but I can't justify the expense of a true MAF kit on this car, and I love to tinker
Nothing wrong with "tinkering" I too like to tinker, though I've been experimenting with my afm. I took a shot glass worth of aluminum out of it by smoothing the restrictions and casting marks, as well as matched the inlet and outlet ports to reduce turbulance. Works great so far. I'm about to do it again on my dd, though I will still likely tryout a custom maf when it is available for the n/a. My cost so far...a couple of dremel bits, and an hour of my time.
Keep going with it, and keep us posted!
This car is an n/a, did you watch the video? Haha.
ZR8ED - I guess you didn't take away any material around where the flapper door goes? Learning to "port" things without messing them up is something I'd like to be able to do, but I've heard if you don't know what you're doing you'll end up doing more harm than good.
For now I've zero'd out the air temp fuel compensation with my ostrich, but I may add an IAT sensor if I can find one cheap enough. I'm guessing that is whats causing my poor throttle response before the car is warmed up. Once the car is warm it feels almost normal.
Also, my first tank of fuel with the MAF came out to 24.2 mpgs, which is pretty impressive considering the way I drive
More scientific observations to come!
Cheers!
I put my AFM back
In conclusion: There was a little gain up top, or it was just nosier, but it wasn't worth the driveability problems for a DD. Anything over half throttle below 3000 rpms would make the car stumble, and I had to drag the clutch a little more to get going without bogging down. On the track I would use the MAF because the rpms are always higher and throttle respone was not an issue after the car had been running for a few minutes.
I put my AFM back
Yeah, I haven't seen too many people on here who've actually done this and posted results.
I'm sure if I got a wideband and spent some time tuning it I could make it perfect, but quite frankly I just don't like this car that much
EDIT: Just to be sure we're clear this is on my 84 n/a. My username and avatar might suggest otherwise
Working on my Turbo and N/a at the same time right now most of my Turbo stuff is in but idk something about the N/a and performance or improvements excites me a lot more.
Also the MAF is back in, I've got most of the kinks worked out using tunerpro, which I talk about a little here:
http://dirtyturbo.blogspot.com/2012/...onversion.html
